Rehan Posted October 3, 2020 Posted October 3, 2020 (edited) Hi there, The abs light on my glanza v came on after converting it to manual Fault code 47 not sure what issue is Thanks Edited October 3, 2020 by Rehan Quote
Claymore Posted October 3, 2020 Posted October 3, 2020 7 hours ago, Rehan said: Hi there, The abs light on my glanza v came on after converting it to manual Fault code 47 not sure what issue is Thanks According to this: Code 47 = Throttle Position Sensor (TPS) or Circuit. The glanza's use a different throttle position sensor from auto to manual. Did you swap everything from the manual car? Loom, throttle body, ECU, etc? Never done it myself but I hope this helps point you in the right direction. Quote
Rehan Posted October 3, 2020 Author Posted October 3, 2020 2 hours ago, Claymore said: According to this: Code 47 = Throttle Position Sensor (TPS) or Circuit. The glanza's use a different throttle position sensor from auto to manual. Did you swap everything from the manual car? Loom, throttle body, ECU, etc? Never done it myself but I hope this helps point you in the right direction. I'm using the auto loom ecu etc Done it in the past and worked fine Engine code and abs codes are Diffrent I think Quote
Claymore Posted October 3, 2020 Posted October 3, 2020 https://www.toyotagtturbo.com/community/index.php?threads/abs-diagnostic.28380/ They are separate codes. It appears there is no ABS code 47. Quote
Sam44 Posted October 3, 2020 Posted October 3, 2020 I read somewhere. I think it was lukep early v build maybe ask him. From what I've read he did 1 of the first auto conversions. The throttle body will be missing a 5v supply from the ECU with the box/loom removed. Check that there is a 5v supply at the 4 pin plug. Quote
Rehan Posted October 4, 2020 Author Posted October 4, 2020 12 hours ago, Sam44 said: I read somewhere. I think it was lukep early v build maybe ask him. From what I've read he did 1 of the first auto conversions. The throttle body will be missing a 5v supply from the ECU with the box/loom removed. Check that there is a 5v supply at the 4 pin plug. Thanks I'll check and update Quote
