bailiff666 Posted May 29, 2021 Share Posted May 29, 2021 Need some advise. Boost creeping. Tong turbo hybrid TD12 internal gated (waste gate ported), FMIC, HKS actuator, Walbro 255, Tuning Development Manifold/Decat, Fujitsubo exhaust 2,5’, DET3 piggyback ECU, Boost creeps every single time when over 5000 revs and get cutoff. ECU cutoff is set to 1.2bar. I’ve install catalyst to restrict exhaust side but no luck. What’s my options now? Electric boost controller or external wastegate? appreciate any advice Quote Link to post Share on other sites
Sam44 Posted May 30, 2021 Share Posted May 30, 2021 is the actuator working correctly (opening fully) are you using a electronic boost controller? im just researching your turbo now. Quote Link to post Share on other sites
bailiff666 Posted May 31, 2021 Author Share Posted May 31, 2021 Hi Sam44 actuator works correctly and I don’t have any boost controller. I have piggyback ecu which allows me to set safety cutoff and it’s set to 1.2bar. Every single time when engine is over 5000rpm I’ve got cutoff. Without this restriction boost will go to 1.6bar. Quote Link to post Share on other sites
Sam44 Posted May 31, 2021 Share Posted May 31, 2021 (edited) interesting. were is the waste gate situated. do you have any pics of the turbo and down pipe/decat pipe on it. could there to any restrictions in there to reduce waste gate flow. some of the down pipe i have are designed for an external gate setup. also how is the actuator boost pipe routed/any other pipes "t" in to it. have you checked this for leaks/blockages. silicon sealant normally the culprit here or a bit of old gasket passed threw the turbo. if you turn the boost down does it operate correctly/no boost creep. Edited May 31, 2021 by Sam44 Quote Link to post Share on other sites
zaffydoo Posted November 20, 2021 Share Posted November 20, 2021 On 6/1/2021 at 3:04 AM, bailiff666 said: Hi Sam44 actuator works correctly and I don’t have any boost controller. I have piggyback ecu which allows me to set safety cutoff and it’s set to 1.2bar. Every single time when engine is over 5000rpm I’ve got cutoff. Without this restriction boost will go to 1.6bar. Found a solution to this my guy? Quote Link to post Share on other sites
