Nilz90 Posted July 20, 2021 Share Posted July 20, 2021 Hello, does anyone know when you have an apexi map sensor for the Power FC do I have to T a hose into my original map sensor on my EP82 or what do I do with the existing one if it’s direct fit? Also what the middle wire is for in the picture it came with the map sensor? Thanks Quote Link to post Share on other sites
H_D Posted July 22, 2021 Share Posted July 22, 2021 Use a celica gt4 map sensor, its a direct fit but the tuner will need to scale it Quote Link to post Share on other sites
Nilz90 Posted July 22, 2021 Author Share Posted July 22, 2021 On 7/22/2021 at 8:53 PM, H_D said: Use a celica gt4 map sensor, its a direct fit but the tuner will need to scale it Expand I’ve got the apexi one now so might as well use that as it’s also a direct fit into the side of the ecu just not sure if I have to T it into my old one or just take the map sensor hose out and plug the new one direct into the intake Quote Link to post Share on other sites
