Guest Enzo Posted May 16, 2008 Posted May 16, 2008 some might slate me but i wouldent bother to be honest, the only way they could ever findo out is if they stripped the engine, as underneath the manifold is the only clue Quote
kroozin Posted May 16, 2008 Author Posted May 16, 2008 yeh i was thinking that but wasnt sure on the forum guidelines on what (not) to say. Anyway just blame someone else It was done before i got it... Quote
StarletRick Posted May 16, 2008 Posted May 16, 2008 all 4/5e heads are the same casting wise. i have had all different variants of them (4efe, 4efte, 5efhe and 5efe) they are all the same. the 4efe springs are pretty weak and wont let you rev over about 7 as they start floating the valves. 5efe is pretty much the same. the 4efte head has slightly stiffer springs, they rev to 8 without trouble.the 5efhe has stiffer springs (like the fte) and also the exhaust cam on the ACIS/Cynos variant has a slightly higher lift.ive got a set of FTE valve springs laying about somewhere, you can have them if you like/i can find them. they are the only difference between the fe and the fte heads.hope that helps. Quote
kroozin Posted May 16, 2008 Author Posted May 16, 2008 wow, thanks alot. It's ok, i dont even own a starlet yet Ill have to bookmark this thread looks like this is a must on an n/a mod list, looking for 100-120 bhp but keeping it reliable thanks alot to everyone im guessing i need a toyota tarcel 5e-fhe head. Quote
Guest Enzo Posted May 16, 2008 Posted May 16, 2008 the 5e-fhe came in the japanese cynos(paseo)and toyota sera, im not aware of them bein in the tercel bud,good luck with whatever you decide to do though Quote
kroozin Posted May 16, 2008 Author Posted May 16, 2008 thanks, ill probly end up with 4efte springs as my searching isnt finding parts to be sent to the uk thanks alot guys Quote
