As above, need to remove passenger air bag. I obviously know that fuse has to be removed first. Does anyone know what fuse it is and what fuse box its in (under bonnet or in little one under steering wheel), and how do you remove the airbag from dash? I only ask as i have a baby due shortly and cant have car seat in car with air bag there. Oh by the way, this is on a glanza.
not sure which fusebox it is in, check the little pics and you should be able to find it!
as regards to the airbag, can you not switch yours off with the key? some cars have like
a little ignition barrel on the passenger side of the dash where the door closes, with the option of turning off the airbag?? :rolleyes:
if not then its dash out time! :rolleyes: you could try reach it from the glovebox hole but you wont be able to see what you are doing?
hope this helps!
alan
Sounds like fun then.
So just to confirm, i need to dis-connect battery; remove fuse; take out glove box; dis-connect air bag; un-bolt airbag; remove everything; put everything back together again.
Correct me if i got anything wrong with that.
