Randy McShag Swindon Posted May 17, 2008 Share Posted May 17, 2008 As above, need to remove passenger air bag. I obviously know that fuse has to be removed first. Does anyone know what fuse it is and what fuse box its in (under bonnet or in little one under steering wheel), and how do you remove the airbag from dash? I only ask as i have a baby due shortly and cant have car seat in car with air bag there. Oh by the way, this is on a glanza. Quote Link to post Share on other sites
alan0387 Posted May 19, 2008 Share Posted May 19, 2008 not sure which fusebox it is in, check the little pics and you should be able to find it!as regards to the airbag, can you not switch yours off with the key? some cars have likea little ignition barrel on the passenger side of the dash where the door closes, with the option of turning off the airbag?? if not then its dash out time! you could try reach it from the glovebox hole but you wont be able to see what you are doing?hope this helps!alan Quote Link to post Share on other sites
SiCaln Posted May 20, 2008 Share Posted May 20, 2008 they dont no, but hey do have a seperate control box behind the dash which if u disconnect the battery u can disconnect Quote Link to post Share on other sites
Randy McShag Swindon Posted May 20, 2008 Author Share Posted May 20, 2008 any more info on that sicaln?is it going to be hard to remove the airbag then?i was under the impression that if its fitted, then by law it has to be connected. Quote Link to post Share on other sites
SiCaln Posted May 20, 2008 Share Posted May 20, 2008 its not easy ud have to take out gove box disconnect and then unbolt Quote Link to post Share on other sites
Randy McShag Swindon Posted May 20, 2008 Author Share Posted May 20, 2008 Sounds like fun then.So just to confirm, i need to dis-connect battery; remove fuse; take out glove box; dis-connect air bag; un-bolt airbag; remove everything; put everything back together again.Correct me if i got anything wrong with that. Quote Link to post Share on other sites
SiCaln Posted May 20, 2008 Share Posted May 20, 2008 got it in 1 Quote Link to post Share on other sites
Randy McShag Swindon Posted May 20, 2008 Author Share Posted May 20, 2008 lovely. looks like i got a fun weekend then. gotta fit speedo convertor and change milage aswell. Quote Link to post Share on other sites
StarletRick Posted May 20, 2008 Share Posted May 20, 2008 you do know youll have a hole in your dash now? why are you taking it out? Quote Link to post Share on other sites
Randy McShag Swindon Posted May 21, 2008 Author Share Posted May 21, 2008 Rick, i would expect you to read a whole topic before posting. You upset me!!!! Quote Link to post Share on other sites
