Tayyib Posted May 24, 2008 Posted May 24, 2008 hi all,im going to be fitting my glanza doors on to my car in the next couple of days, im wanting to know what i will need to have the power windows working, such as the window regulators, and if there is a how to for this (i searched but couldnt seem to find it), as my car is a sportif and has manual windows.thanx Quote
nic1.3 Posted May 24, 2008 Posted May 24, 2008 hi all,im going to be fitting my glanza doors on to my car in the next couple of days, im wanting to know what i will need to have the power windows working, such as the window regulators, and if there is a how to for this (i searched but couldnt seem to find it), as my car is a sportif and has manual windows.thanxhey mate to get the power windows working ud needelec motors and regulators to suitthe wiring loom form the doorsthe switches Quote
Idrees Posted May 24, 2008 Posted May 24, 2008 i wanna fit 'leccy windows. tired of these keep fit ones. is the loom already in place then? even if the car is not fitted with electric windows? i would presume so, as making different looms for one car would be a bit daft. (i could look myself but can't be arsed ;) )We think it is already in place but we haven't checked! Quote
steviet Posted May 25, 2008 Posted May 25, 2008 The only loom you need is the loom in the door for the electirc windows,and the plugs should be in the cars kick panel to wire the electircs into the window reg etc. Quote
Bourkey Posted May 25, 2008 Posted May 25, 2008 Yep all the wires are tucked under the carpet or under that bit of plastic next to the footwell. It's a white or blue plug if i remember correctly. Just whack the doors on and plug them in. Bourkey Quote
nic1.3 Posted May 26, 2008 Posted May 26, 2008 Yep all the wires are tucked under the carpet or under that bit of plastic next to the footwell. It's a white or blue plug if i remember correctly. Just whack the doors on and plug them in. Bourkey"IdreesThanks (from Tayyib)Where do the regulators go?that is correct about the wiring the piece of the loom that u need is only going from the door to just inside the footwell.as for the electric regulators these replace the "keep fit ones" is just a matter of undo the manual regulators and then replace with elec regulators.also i forgot to mention that u will have to drill the doors and pillars in order to fit the wiring and fit a set of those flexi tubes that u see in other cars, its more awkward then difficult but it will allow u to fit all sorts of electrics in the doors afterwards eg speakers, central locking. Quote
Tayyib Posted May 26, 2008 Author Posted May 26, 2008 thanks mate, will give this a go on thursday and see how it goes. thanks again Quote
Idrees Posted May 26, 2008 Posted May 26, 2008 We will be fitting complete new doors so no need for drilling Quote
nic1.3 Posted May 26, 2008 Posted May 26, 2008 We will be fitting complete new doors so no need for drilling hey idrees if its glanza doors your using then ya ull be fine.but did your starlet come with electricsof some sort in the doors originally if not then u will still need to drill the pillar. Quote
Idrees Posted May 26, 2008 Posted May 26, 2008 Ah I see what you man now, nope didn't come with electrics so we will need to drill the pillar!These are being fitted to Tayyibs Sportif (my brother) Quote
nic1.3 Posted May 26, 2008 Posted May 26, 2008 oh rite. i didnt know that he was your bro...when i did the electrics i went to the breakers and got sum of the flexi tube things and drilled out the holes with a hole saw... Quote
Barneyboy1997 Posted May 26, 2008 Posted May 26, 2008 its not that easy. i fitted electric windows out of a cd into my sportif on monday. You will also need the relay that powers them. The relay is under the dash trim where the front speakers are. With out they wont work Quote
Tayyib Posted May 30, 2008 Author Posted May 30, 2008 We got the relays yesterday too but they electrics are still not working.Can you describe the relays? We got them out of a GT so just wondering whether they are the same Quote
Barneyboy1997 Posted June 1, 2008 Posted June 1, 2008 We got the relays yesterday too but they electrics are still not working.Can you describe the relays? We got them out of a GT so just wondering whether they are the sameI'll take a couple of pics tomorrow for you Quote
Idrees Posted June 1, 2008 Posted June 1, 2008 Got it sorted now mate so no worries. Thanks for all your help Quote
faziel Posted January 30, 2010 Posted January 30, 2010 Got it sorted now mate so no worries. Thanks for all your help im having the same problem here.when i fit al the wires together it shoud work but it doesnt.does any one have a part number of the relay or is it just one universal relay.also i cant fint the place where the relay should fit.my instruction book says its a power 30A fuse.but there must be any relay to.or does any one have a how to or something like that. Quote
