keep gettin water in one of my rear lights, im just wondering can i take the light apart without damaging it , and also i cant see anywhere where it might be getting in has anyone alse had this sort of problem?
thanks
I'm sure I've got a similar problem but haven't bothered to look into it, does your boot get damp/wet and does your car smell a bit funny sometimes?
mines not that bad its just the light, that gets water in it.
rear lights just unbolt. doesnt take long, sounds liek a seal has gone, youll be able to get a new one for peanuts from toyota.
i've had the light off i just wasnt sure wether to unclip the lense to get the water out, will it just fit back together if i do that? or will i have to re seal it or something?
you should be able to put it back together prety easy. just use some clear silicone sealant.
thanks, i thought i might need to use some sealant to put it back together just wanted to make sure before i took it apart.
oh and not really on topic but do you mean sk8 as in skateboard or rollerblading?
and you live in stockport I'm guessin you've been to Bones or whatever it these days the UKSkate park?
yeah im a skateboarder not rollerblades, i did go to bones/ukskate quite alot a few years ago but not so much anymore its too expensive
