when i switch on my lights. the rear brake lights come on without pressing the brake. when i do press the brake they get brighter but still stay on. its a n/a and the light on the bottom right doesn't work?
what lights should be on when i switch my lights on?
any ideas of how to fix?
cheers craig
No. That is your lights working how they should. Every single Starlet works like that.
The one on the bottom right is your fog light, which will come on when you switch your fog light on.
Hope this helps bud.
Bourkey
As above but i had a little problem like this
My brake lights came on when i turned the lights on it turned out to be because the wottage/voltage or whatever it is on the bulb was to powerful or to weak or sumin justy check your bulbs right n not to powerful or sumin
Hope that helps :D
Hope that helps :D
Ditto, have seen that on some cars before, the wrong wattage bulbs. Go check them and see :D also, could be a difference if u swap bulb round in how it's sitting...... if that makes sense......... dunno why, but sometimes it makes a difference.
dont tell him to check his bulbs.
they are right, thats how it should operate!
should the middle light be on? because it is on all the time. cheers craig
