Mart Posted June 16, 2008 Posted June 16, 2008 Can any tell me the proper way to raise the ride height of D2 Coilovers?From the diagram below, which collors do I need to adjust? which don't effect messing up the spring's tension?Or Does the coilover need to be fully disconected from bottom area where the Disc is mounted on?Thanks Mart... Quote
Mart Posted June 16, 2008 Author Posted June 16, 2008 Quick bump...Anybody know the correct way? Quote
59bhp Posted June 17, 2008 Posted June 17, 2008 all you need to do is at the bottom of the spring there are two rings, wind the bottom one down first so that you are free to move the top ring, wind it up if you want to lower it and down if you want to raise it. Then wind the bottom ring up against the top ring to lock the whole thing off and jobs a good'n, Quote
Mart Posted June 17, 2008 Author Posted June 17, 2008 To be honest mate, thats the way I was going to raise it myself but I read thats the total wrong way to adjust them, as it compresses the springs tension. It even states this aswell in the D2 leaflet so Im clueless now... Quote
StarletRick Posted June 17, 2008 Posted June 17, 2008 thatll change the spring tension. to change just the height, you have to spin the base of it that bolts to the hub. Quote
Mart Posted June 17, 2008 Author Posted June 17, 2008 Cheers for the help Rick, So I need to disconect the coilover from the hub first, then rotate it. Is it a hard job the disconnect from the hub or only a case of just unbolting the nuts holding it?Thanks again for the help Rick. Quote
59bhp Posted June 17, 2008 Posted June 17, 2008 well fuckin hell you learn somethin new everday. Do all coilovers come like that as im sure my bro's FK's didnt. Quote
addz Posted August 10, 2008 Posted August 10, 2008 I also have the D2 kit.I want a smoother ride as my car is currently sitting low.Will i have to de-assemble the whole arm to adjust ride height size? Quote
