Silly question but I can't find a true figure...always just pour until I get bored.
What's the stock EP82 take to fill? anyone got any ideas on how much extra oil is needed to charge the Greddy oil cooler system (with relocator)
The car has got 4 litres in it at the moment, need to get it spot on before the trip!
3 quarts to fill up a stocker, so that, plus whatever your cooler holds, probably another quart.
I wondered on this myself, as I have just bought the same kit second hand, so no instructions.
It usually takes I think 3.5l to fill the engine..not sure how much extra is needed when the cooler kit is fitted.
I take it all the oil goes back to the sump when turned off, so you can't fill, run, turn off, check level, fill and turn back on like when you fit an oil filter?
Seen some coolers located real low down thou..
