Rich Posted August 20, 2008 Posted August 20, 2008 Well the other day I took my throttle body off to give it a good clean, there were some nasty deposites on it and Idle was dropping to 500rpm on occasions.Then I noticed inside the inlet manifold there was a nice pool of oil so I whipped that off and gave it a good clean also.Now my question is, Is it against the law (MOT law ) to have an oil catch can attached to the PCV? Quote
paul w Posted August 20, 2008 Posted August 20, 2008 No i doubt it, but it's a closed loop for the vacuum isn't it? Quote
Rich Posted August 20, 2008 Author Posted August 20, 2008 Yeah I think so, but if you kept it as a closed loop but had it detour into a container of some sort, it should still work. Theoreticly Quote
nic1.3 Posted August 20, 2008 Posted August 20, 2008 Well the other day I took my throttle body off to give it a good clean, there were some nasty deposites on it and Idle was dropping to 500rpm on occasions.Then I noticed inside the inlet manifold there was a nice pool of oil so I whipped that off and gave it a good clean also.Now my question is, Is it against the law (MOT law ;) ) to have an oil catch can attached to the PCV?hey mate I've wondered the same thing previously, I was thinking is the cusco oil catch can a closed loop system or what. In the photos for it on the RHDJapan site it has 2 blue connections for hoses at the top so i guess that it could be connected to the PCV with just sum extra hose . Quote
StarletRick Posted August 20, 2008 Posted August 20, 2008 your pcv wont open up if it isnt attached to the pelnum, its vacuum operated. i dont have a pcv at all, and i pass my mot ^^ Quote
ChineseMafia Posted August 21, 2008 Posted August 21, 2008 your pcv wont open up if it isnt attached to the pelnum, its vacuum operated. i dont have a pcv at all, and i pass my mot ^^HEY RICK DO I NEED THE PCV VALVE ?CAUSE THE NOZEL BROKE SO I WAS THINKING I WOULD PUT A BRASS BARB AND AN OIL CATCH CAN WILL THAT AFFECT PERFORMANCE OR MY ENGINE ? Quote
StarletRick Posted August 21, 2008 Posted August 21, 2008 you dont need one no. i dont have one. i have mine running yo a catch tank. just make sure that if you run both the vents in the cam cover to a catch tank that you MUST HAVE A VENT IN THE CATCH TANKif the tank isnt vented youll cause a world of problems. Quote
