Galliano Posted September 3, 2008 Share Posted September 3, 2008 Here is a quick How-To I originally made for Sparky to help him out, but I thought I should post it here too, just incase more people want to do this and don't know how.Please Bear In Mind, I Did This Using A Paseo, But As Far As I Am Aware They Are Almost Identicle Behind The Scenes 1. remove headunit, center console and whatever you need to have the center console out on your lap.2. take the ashtray unit out (2 screws up the top pull out)3. remove brackets from the both units, then fit the brackets from the ash tray to the head unit..4. on the LEFT bracket, the hole that is scratched (from previous position on the ashtray) doesnt line up, use the top hole as shown VVV.So far you should have this :5. pull the wires from the headunit down behind the dashboard line like so VVVV6. plug the wires into the back of the headunit and slide the centerconsole back into place, beware though, the centerconsole gets a bit top - heavysorted.i did this without using my blanking plate under the ashtray, but this still fits but you just need to screw it to the brackets.Galliano Link to post Share on other sites
