Well i know what a bov does and how its operated and works :p , but whats the difference between a twin and single piston bov? is one better than the other? i have a baileys single piston dump valve fitted atm, but i also have a twin piston venturi baileys bov. The single piston one leaks boost when i travel at certain speeds on the motorway and when the throttle peddle is at a certain position, would the twin piston bov sort this? cheers guys starlybrusier :) .
  • 2 months later...
Well i know what a bov does and how its operated and works :lol: , but whats the difference between a twin and single piston bov? is one better than the other? i have a baileys single piston dump valve fitted atm, but i also have a twin piston venturi baileys bov. The single piston one leaks boost when i travel at certain speeds on the motorway and when the throttle peddle is at a certain position, would the twin piston bov sort this? cheers guys starlybrusier :lol: .
i have been having this exact same problem!! did u sort it and find out which is better??? jamie
  • 1 year later...
has any 1 got any info on this can the twin pistons be used on our engines ??????
The problem is simply because it's baileys, get something more reputable as these baileys tend to leak quite a lot. A mate of mine had his leaking from quite a premature/new dv.
to be honest i wanna sale my car but wanna take the hks off so just need to no if a twin piston dump valve wuld fit
any info wuld be great thanks
