boyracerj Posted September 20, 2008 Posted September 20, 2008 Help was driving my car today and then all of a sudden when i went to acclerate all i got was a loud whoosing sound and my boost gauge would go upto "0" but no furthur, felt like the turbo wasnt working at all!!! HELLLPPPPP! Quote
WallaceGlanza Posted September 20, 2008 Posted September 20, 2008 One of the intercooler pipes has popped off. Quote
boyracerj Posted September 20, 2008 Author Posted September 20, 2008 ive had a pipe come off before and it sounds different, couldnt visibly see any pipes come off, sounds like the turbo is still spinning but i have no boost whatsoever, will have to recheck all the pipes Quote
Idrees Posted September 20, 2008 Posted September 20, 2008 Yeah I'd start with checking all the pipes and vacuums. Quote
montanajr Posted September 20, 2008 Posted September 20, 2008 Clip holding actuator arm into the flap has fallen off? lol. Quote
boyracerj Posted September 20, 2008 Author Posted September 20, 2008 thanks for all your help guys i'll have a look into it tomoro, could at worse it be a turbo fault??? something like this would have to happen now that she is up for sale Quote
WallaceGlanza Posted September 20, 2008 Posted September 20, 2008 The turbo will still be spinning but the positive pressure its generating will just be leaking out, it probably sounds different because its a different pipe thats popped off. From what you've described I'd guarantee its an intercooler pipe or hose that has come loose or got a hole in it. Quote
boyracerj Posted September 20, 2008 Author Posted September 20, 2008 cheers guys you diamonds!! i'll have a look at it tomoz!!! Quote
boyracerj Posted September 20, 2008 Author Posted September 20, 2008 hope it is only the intercooler pipe!!!!! am almost glad its happened, will make it easier for me to let her go when she sells lol Quote
boyracerj Posted September 23, 2008 Author Posted September 23, 2008 thanks to you guys who shed a little of you knowledge onto me! turned out to be an intercooler pipe. Shes back running like a beauty again!! thanks again Quote
keirz Posted September 23, 2008 Posted September 23, 2008 a boost pipe popping off sounds much worse than it is when it happens! i did it once on full boost and the fmic piping to the throttle body poped off and twat'ed the underside of the bonnet. properly filled my pants with cake. Quote
boyracerj Posted September 23, 2008 Author Posted September 23, 2008 a boost pipe popping off sounds much worse than it is when it happens! i did it once on full boost and the fmic piping to the throttle body poped off and twat'ed the underside of the bonnet. properly filled my pants with cake.tell me about it! it made a almighty pop as the pipe slipped off and then no boost and alot of whooshing, cant help but fear the worst!! Quote
SooperD Posted September 23, 2008 Posted September 23, 2008 good old turbo engines.. we always fear the worst when things aint running as they should Glad u got it sorted mate Quote
