I read somewhere that the older generation of 4EFE's, (the one found in the EP80) came with a 4-2-1 manifold instead of the 4-1 that we get on the EP91's.
What sort of difference would you get, I know with different manifolds you get more power at difference rev ranges, but I can't remember any of it, someone wanna shed some light? :mellow:
Basically what I want to know is which one would be better for low end/mid range/top end.
And if they're both a straight swap.
thanks in advance
Generally Speaking 4-2-1 broaden the power range and 4-1 Increase top end.
But If you get a decently made 4-2-1 with long primaries and tapered collectors then you should get the best of both worlds :mellow:
hey Rich
I understand what you mean by long primaries.......but what do you mean by tapered collectors???
sorry if this sounds stupid man.
nic
Basically :mellow: say the first set of pipes out of the engine (primaries) collect into a slightly larger secondary and then the two secondarys collect into a larger collector which tapers down to smaller (same sizes as a secondary ? ) so it flows better.
I have a standard 4-2-1 not sure if it will fit on my exhaust but I might try it one day :D
Aint you getting an FTE? :ph34r: I you are and wana get rid send it my way for free yeah? :D :D
