adi-izzle Posted October 6, 2008 Posted October 6, 2008 why is my mk1 starlet gt feel like (over bumps more than anything) when i'm braking, the back end seems to twitch from side to side? I know my back shockers are leaking slightly, is this causing it? Quote
keirz Posted October 6, 2008 Posted October 6, 2008 mine is the same under hard breaking, i think an upgraded panhard rod helps to reduce it. im not 100% certain that this would be your problem but it will definatly help strengthen up the rear axle Quote
damotep82 Posted November 20, 2008 Posted November 20, 2008 mine is the same under hard breaking, i think an upgraded panhard rod helps to reduce it. im not 100% certain that this would be your problem but it will definatly help strengthen up the rear axlei have the same i know my rear caliper on 1 side is not pulling as stong as the other side so it twitches like hell when i hash brake,so i just thought it was that ,it could be worth checkin if u find any more solutions could u please give us a shout cheers Quote
SiCaln Posted November 21, 2008 Posted November 21, 2008 yea check the brakes, bleed the system and add new fluid, panhard rod could be useful if lowered, but definitely a rear arb to tie the whole rear end to the rest of the car Quote
