after a week joyful ridin I wan boost my car up.
I have done exhaust and air and boost gauge so far.
I am after a dump valve and manifold and boost control?
but de question is which 1? and which 1 is first ?wat prob should I look 4?
how much improvement i will get?
so many ques!!! sorry
this is my first turbo charge car
thanx in advance
depends on how much you want to spend really. hks and blitz make good boost controls and awesome sounding dump valves but are quite costly.turbo xs and turbo smart are also good.might want 2 think about a fuel cut defencer as well if your going 2 be upping the boost. :lol: dump valve will give you the noise(if its atmospheric) and reduce lag.boost control does what it says on the tin but wud prob recomend an in car electronic one,as you can adjust it as an when you like.front mount intercooler will be a big help as well,heat soak is a big problem especially with summer coming up! i would go 4 dump valve first, then boost controller with a fuel cut defencer.prob de-cat and front mount after that....if you still have the money!
hope thats some help to you <_<
Thanx very much, you been very helpful. I will go 4 dump valve first because I like the noise. I turned the cat 2 decat by knocking out the filter, but will get a proper one. What brand of boost controller and what kind of dump valve do you recommend? How much power would I get after all this?
Cheers, Moss
before doin anything have you tried the hi low boost mod yet?
it takes the low boost limiter in hte first two gears that you might have discovered
clicky
just open up your bonnet and replicate the pic,
should put a smile on your face if you have not done it already....
if you can aford a hksssqv plump for that but blits is also another quality brand,
with a boost controler your limited to the amount of boost you can turn up due to the top mount among other things
hey enzo your clicky didin't opened up, can you send me another one,
I think I go for hks after all,
my only prob is engine mangemanet light comes up some times any idea ?
im stumped on the engine light, whatever it is wont be good news
just replicate the pic, for more added turbo fun B)
Have you checked your fault codes to see why you management light is coming on?
Short TE1 & E1 in the diagnostics box with a paperclip and your management light will flash depending on the error.
Error codes:
10 STA
11 +B switch signal, ECU/ECM
12 Ne, G, STA KNK
13 Ne knock control CPU (ECM)
14 IGt, IGf turbocharger pressure
21 OX, HT
22 THW
23 THA
24 THA
25 OX lean
26 OX rich
27 OX2
28 OX2
31 AFM equipped: Vc open, VS-E2 short
MAP equipped: PIM
32 E2 open, Vc-Vs short
34 turbocharger pressure
35 turbocharger pressure
41 IDL, PSW
42 SPD
43 STA
51 A/C, IDL, neutral switch
52 KNK
53 KNK
54 intercooler ECM
71 EGR system
72 fuel cut solenoid
78 fuel pump control
81 TCM communication
83 TCM communication
84 TCM communication
85 TCM communication
When your engine management light comes on it means something is wrong. Ok so now you need to go out to your car and;
  • Go into the engine bay and open the fuse/diagnostic box (little black box on the left-hand side of the engine bay) And the underside of the lid will show you the pin layout.
  • Bridge pins TE1 and E1 (with a paper clip or bit of wire)
  • Turn ignition on (but don't actually start the car)
  • The engine management light will start to flash
  • It will flash say 4 times **** then a short pause
  • It will then flash say once *
  • This means error code 41 ie. Idle speed prob
  • The management light will then start flashing another error code (they may be more than one fault) or have a short pause and repeat the same code over again
  • Then refer to the list above or the diagram below to see what the error is
Hope that helps mate
i think you'll find the engine management light is fuel cut
He never mentioned having any of the effects of fuel so I thought I'd just pop that up to help diagnose the prob.
fcd's
try starletgtturbo.co.uk, but your best off with a fual computer like a gredy e manage that will sort that out anyway and give you an extra 30plus bhp
did you try that hi boost mod?
