Kennedy Posted November 22, 2008 Posted November 22, 2008 Wondering is someone can help me.Just been told i need new sparks plugs..so i'm gona have to go get them tomorrow.Which ones do i need? I'm gonna have to go halfords or somthing so if some1 could find the right ones on there website that would be great ive got a 96 glanzaThanks Quote
Jozinobi Posted November 22, 2008 Posted November 22, 2008 You ideally want a set of 4x NGK Iridiums IX mate in heat range 7 for your Glanza.I've just been on halfords site and their plug range is confusing as hell.I have a set of 7's here in front of me.The codes on it are : BKR7EIX - Stock No 2667.Because you need them asap your best bet may be halfords.However if you can wait a few days, Dave Burwash (reliable trader) can get you some sent asap as he always has service items in stock - his number is 07852 295221, I'd give him a shout tonight.He is located in Essex.Joz Quote
Kennedy Posted November 22, 2008 Author Posted November 22, 2008 i need the car sorted for monday for work really..the fella whos doin it can only sort it first thing on the mornin aswell =/these will only be a temporary measure anyway..gona give it a good service after christmas Quote
ste91 Posted November 22, 2008 Posted November 22, 2008 Doing what? Changing your sparkplugs?Or is there something else? Quote
Kennedy Posted November 22, 2008 Author Posted November 22, 2008 no just need new spark plugs..need the tomorrow aswell =/ Quote
Kennedy Posted November 22, 2008 Author Posted November 22, 2008 You ideally want a set of 4x NGK Iridiums IX mate in heat range 7 for your Glanza.I've just been on halfords site and their plug range is confusing as hell.I have a set of 7's here in front of me.The codes on it are : BKR7EIX - Stock No 2667.Because you need them asap your best bet may be halfords.However if you can wait a few days, Dave Burwash (reliable trader) can get you some sent asap as he always has service items in stock - his number is 07852 295221, I'd give him a shout tonight.He is located in Essex.JozFound thesewould they be suitable? the code for them is BKR6EK so its close to the 1s recommended..there only gona be temporary till after xmas Quote
Kennedy Posted November 22, 2008 Author Posted November 22, 2008 anyone? i need to know for the morning if possible Quote
Jozinobi Posted November 23, 2008 Posted November 23, 2008 I found this Mike ThreadI think it will help a lot. For the record you need heat range 7, and it says 4EFE is heat range 5, that is incorrect (its heat range 6 )Joz Quote
Kennedy Posted November 23, 2008 Author Posted November 23, 2008 so the one's in the previous post can't be used =/ ?will heat range 6 not be ok for short term? Quote
Jozinobi Posted November 23, 2008 Posted November 23, 2008 Heat Range 6 is standard for Glanzas Mike.If you are mildly modified I'd defo go for 7's but its not going to do any harm running on the standard plug thats for sure unless you are running a lot of power then you'd need to go for a 'colder' plug.I'd go for them.Joz Quote
Kennedy Posted November 23, 2008 Author Posted November 23, 2008 sweet thanks...its not got many mods..got an electronic boost controller on it which ive got turned off at the min and thats the only main thing.person who had it before me only tried to increase the power before anything else.Hopefully they have them in stock now haha Quote
Jozinobi Posted November 23, 2008 Posted November 23, 2008 Fingers crossed for you mate.Sometimes the simplest of things are the biggest of hassles.PeaceJoz Quote
Kennedy Posted November 23, 2008 Author Posted November 23, 2008 yup in stock..Stupid question..need 4 right? Quote
Jozinobi Posted November 23, 2008 Posted November 23, 2008 You will definately be needing x4 When you get them in the store be sure to check the tips etc are not damaged i.e broken because you need everything to be intact.Joz Quote
Kennedy Posted November 23, 2008 Author Posted November 23, 2008 brilliant..thanks for your help mate Quote
Jozinobi Posted November 23, 2008 Posted November 23, 2008 Did you manage to get these sorted Mike?Joz Quote
Kennedy Posted November 23, 2008 Author Posted November 23, 2008 Yup went and got them..took them to be fittedturns out there was a bit of water in 2 of the plugs..dried them out n now its fine..so took the plugs back and got a refund Gonna buy some of the 1s u recommended though and get a good service done after xmas.Thanks for your help Quote
Jozinobi Posted November 23, 2008 Posted November 23, 2008 Excellent mate. Glad you got to the bottom of it.Joz Quote
Kennedy Posted November 23, 2008 Author Posted November 23, 2008 just so people know..the plugs were slightly different to the 1s that were in my glanza so i can't confirm if they fitted Quote
Jozinobi Posted November 23, 2008 Posted November 23, 2008 Thanks for that info.Just be sure to buy your new ones from a starlet parts trader and you'll be flying.Joz Quote
