Dan Evans Posted December 18, 2008 Share Posted December 18, 2008 Heey guys, I've just bin out to my glanza uprating the standard front speakers and as i was dismantaling the dash somthing caught my eye right by the ECU, on closer inspection there is a little black box with jam written on it, it says for proffesional use, its got three wires coming out of it red, white and green.What is it????cheers guys Quote Link to post Share on other sites
Mart Posted December 18, 2008 Share Posted December 18, 2008 Sounds like a FCD or equivilent... Quote Link to post Share on other sites
WallaceGlanza Posted December 18, 2008 Share Posted December 18, 2008 Yup a JAM FCC,means the fuel cut limit is raised however to be safe you could still do with some form of after market fuelling if you're running over the original fuel cut level (12.5psi ish). Quote Link to post Share on other sites
Dan Evans Posted December 18, 2008 Author Share Posted December 18, 2008 well I've bought an after market fuel pressure regulater and now looking at an hks fuel rail. will that do or some more?? Quote Link to post Share on other sites
WallaceGlanza Posted December 18, 2008 Share Posted December 18, 2008 well I've bought an after market fuel pressure regulater and now looking at an hks fuel rail. will that do or some more??Yeah the fuel regulator will be sufficient but you need it setup and the fuelling checked using a wideband on a rolling road, the fuel rail does nothing except look pretty... Quote Link to post Share on other sites
Dan Evans Posted December 18, 2008 Author Share Posted December 18, 2008 got ya cheers mate Quote Link to post Share on other sites
Guest Enzo Posted December 18, 2008 Share Posted December 18, 2008 do you have a boost gauge, what is it boosting too now? Quote Link to post Share on other sites
Dan Evans Posted December 18, 2008 Author Share Posted December 18, 2008 im new to the turbo scene, it goes up to 1 bar on high boost, and 0.5 on low boost, dat good or bad?? cheers Quote Link to post Share on other sites
Mart Posted December 18, 2008 Share Posted December 18, 2008 Depends really mate, Are you still rollin on the standard exhaust manifold?What other mods do you have bro? Mart... Quote Link to post Share on other sites
Dan Evans Posted December 19, 2008 Author Share Posted December 19, 2008 yeah it is standard mani and cat, but im lookin at gettin both uprated.spec so far...Kakimoto racing exhaustsamco hosing lowered 40mm on tein springs with trd shocksapexi Filterjust bought rrfpr and looking at hks fuel rail and oil catch can and fmic Quote Link to post Share on other sites
WallaceGlanza Posted December 19, 2008 Share Posted December 19, 2008 I reacon it muct have a jam actuator too if you're boosting 1 bar. Running that much boost isn't really a good idea on the stock mani and stock intercooler, and especially with no fuelling mods. Quote Link to post Share on other sites
Dan Evans Posted December 19, 2008 Author Share Posted December 19, 2008 ok, I've been looking at a new manifold and de cat.will i need to uprate the intercooler??? i have been looking at a fmic anyway. Quote Link to post Share on other sites
Dan Evans Posted December 19, 2008 Author Share Posted December 19, 2008 ok, o if i get a rrfpr and fuel rail and bigger injectors, with a new mani and decat, should that do the trick??? Quote Link to post Share on other sites
Mart Posted December 19, 2008 Share Posted December 19, 2008 First step is to get a new Exhaust Manifold. As said above the last thing you want is to pop piston no3 especially with the restriction in the stamdard mani.Then sort out your fueling. Quote Link to post Share on other sites
Driver Posted December 20, 2008 Share Posted December 20, 2008 cars come in with jam actuator and jam FCC is there a sticker on the middle of the ECU saying "JAM" on it aswell ??also if it itsnt a JAM ECU 1st thing ide sort is fueling as ide rather pop cylinder 3 then run leanmy advice take it steady untill you get fueling and mani, or port mani out atleast Quote Link to post Share on other sites
Dan Evans Posted December 20, 2008 Author Share Posted December 20, 2008 no it aint a jam ecu, im looking for a decent manifold, anyone got any ideas<< also im going to gut my cat rather than buy one for now, then get it on the rolling road and get the fuel reg on. Quote Link to post Share on other sites
