kevink Posted January 16, 2009 Share Posted January 16, 2009 i thought this may come in handy for future reference.i remember looking for pics like this for ages, now i have them myself so i thought i'd better share there you go!to swap them is pretty easy i must say. forgot to make detailed pictures! but here is the step by step explanation:-Undo lightclips, like when replacing bulbs-Remove indicator by unscrewing top lil screw and pulling it the indicator forward. (the indicator is connected at the bottom with a pin in a hole (#1 on picture))-undo bolt with spanner(10mm)(#2 on picture)-the headlight is now still connected on 2 spots(#3 & #4)-on spot #3 to loosen, you have to lift the light-on spot #4 to loosen, you have to move headlight towards the indicatorside(this is the reason you need to remove indicator, you need the space)-both spot 3 and 4 should come loose at the same time.thats about it you have the headlights loose now.hope its off any use!- Link to post Share on other sites
Guest Enzo Posted January 16, 2009 Share Posted January 16, 2009 sweet dude Link to post Share on other sites
wchtim Posted January 22, 2009 Share Posted January 22, 2009 nice one...have been looking for this info for long time!!GOOD JOB! Link to post Share on other sites
Minorand944man Posted May 21, 2009 Share Posted May 21, 2009 http://img.photobucket.com/albums/v697/Kev...t/headlight.jpgthats about it you have the headlights loose now.hope its off any use!Thanks Kevin K! I just had to replace a headlight for the MOT and your post saved much head scratching, as I cannot find a workshop manual for the Starlet. I'm used to 1960's cars- modern stuff is a mystery- so your diagram was excellent help.Cheers a bunch!John Link to post Share on other sites
Bluebear Posted October 11, 2009 Share Posted October 11, 2009 Was just taking off the headlights so I could get to the adjustment servo or whatever it is (it's loose ), and Dad found out that there's no need to undo the bolt at location 2, the headlight unit just pops off in the same manner as 3 and 4. Link to post Share on other sites
rob_bower Posted April 4, 2012 Share Posted April 4, 2012 Not on mine dude that adjuster is rock solid no way it will pop off. You must be luck Link to post Share on other sites
