Hi all,
got a problem with the passenger side electric window..it doesnt work at all lol
the fella i bought it off said when he had work done on the car the person who sorted it broke the drive side window switch..
ive bought a new driver side window switch..the 1 which was apparently broken but ive still got the same problem.
The window does not go up or down if you use the driver side switch or the passenger side switch..i cant even hear it try to move?
Any ideas?
put a live feed to the motor, thats how i put the window up and now now you have my switches! then u no if its the motor. rule it out, check wiring fuses, power sorce etc. maby a relay sumwhere. eliminate one thng at a time and youll find your problem
Yes definately try a live feed to the motor, i had a similar problem a few months ago with a crook motor.
Take off door trim get a bit of 2-core twin cable jam that on your battery and test it directly on the motor.
  • 4 weeks later...
Sorted..turned out a cable hadnt been connected back properly
As soon as i started taking the door card of it was obvious.
I made the mistake of trying with the button pressed in on the driver side so was a bit gutted thinking it still wasnt working :)
lol i love that button. confuses the shit out of people who get in my car and try light up a cigarette but cant open the window!
