Hey guys I have a bit of a technical question that few may be able to answer precisely and correctly.
Firstly, what is the exact level of boost (in psi or bar) that the fuel cut limiter comes in on the stock ep91 ecu?
Secondly, what is the exact maximum boost that the stock ecu will fuel to? I have read previously that its 13.9 psi. Please someone with in depth knowledge on this, can you let me know.
A lot of people seem to think boost cut comes in a 0.85 bar from what I've read. This does not appear to be the case at all after some peak hold boost monitoring on my avcr when on my way home from work tonight. :D
Any help would be much appreciated :D
Cheers,
Alex
Its not measured by the boost its when the map sensor reads 4.1v which is generally around 12.5 psi but it can vary slightly between cars.
I see, when you say slightly, how much can it vary do you know? my avcr has read .91 bar so far which is 13.2 psi and no fuel cut or ecu light has appeared yet.
There are no other mods to the ecu ie an fcd.
