mel Posted February 17, 2009 Posted February 17, 2009 lowering springs With standard shocks is this safe to do or a bad idea. has enyone done this on there car? what springs have you got on and how low. Quote
Craig_N Posted February 17, 2009 Posted February 17, 2009 Hi there i have Tein springs on standard shocks i dont think it will be good for the long run not shore on that, but they been fine for the time being however i will be eventally change the shocks.Craig Quote
Glanza_cl Posted February 17, 2009 Posted February 17, 2009 loads of people do it (i have coilover though lol) it's not bad but will sacrifice the longevity of the shocks... they might last years or they might only last a couple of months depends on the condition of the shocksyou wont find any springs that's go lower then 40mm on a starlet, teins say 55mm or something like that but i isn't anywhere near that low.i would say do it and then when your shocks go buy some uprated ones Quote
mel Posted February 17, 2009 Author Posted February 17, 2009 Hi there i have Tein springs on standard shocks i dont think it will be good for the long run not shore on that, but they been fine for the time being however i will be eventally change the shocks.CraigHi Craig them are the springs i was thinking of getting do they lower the car much?Mel Quote
mel Posted February 17, 2009 Author Posted February 17, 2009 loads of people do it (i have coilover though lol) it's not bad but will sacrifice the longevity of the shocks... they might last years or they might only last a couple of months depends on the condition of the shocksyou wont find any springs that's go lower then 40mm on a starlet, teins say 55mm or something like that but i isn't anywhere near that low.i would say do it and then when your shocks go buy some uprated onesHi My glanza has only done 28000 miles so shocks seem good just want to lower a bit. Quote
Craig_N Posted February 17, 2009 Posted February 17, 2009 Ye mine has only done 35000 miles so i think they will last for a while. Quote
ToyotaTech15 Posted February 17, 2009 Posted February 17, 2009 I used Pi 40mm lowering springs on standard shocks, that is the lowest ive seen a starlet on standard shock apart from coilovers of course,Gary Quote
mel Posted February 17, 2009 Author Posted February 17, 2009 I used Pi 40mm lowering springs on standard shocks, that is the lowest ive seen a starlet on standard shock apart from coilovers of course,Garydid it give a rough ride or was it fine? Mel Quote
ToyotaTech15 Posted February 17, 2009 Posted February 17, 2009 They werent bad, it did scrape the tyres on certain bumps but wasnt usually bad untill you have about 2 or 3 passengers, it sat quite nice, you can see pics on my build thread before i fitted my coily's,You still get a bit of body roll with them but i found them ok,They arent to expensive brand new, i think you can pick a set up for under £100 now,Would definatly go for either 40mm or coilovers for suspension, i bought 35mm first and they didnt lowered it atol really so it was a waste of money.Gary Quote
SR17 Posted February 17, 2009 Posted February 17, 2009 I also have PI springs on mineRide isnt too bad, just depends on road surface. Take it easy over bumpy roads and of course speed bumbs and you'll be ok Quote
mel Posted February 17, 2009 Author Posted February 17, 2009 I also have PI springs on mineRide isnt too bad, just depends on road surface. Take it easy over bumpy roads and of course speed bumbs and you'll be okok thanks might go for PI springs did you fit a adjustable panhard rod to?Mel Quote
ToyotaTech15 Posted February 17, 2009 Posted February 17, 2009 I didnt, ive only seen afew people doing that but it seemed ok without one,maybe not thou lolGary Quote
Craig_N Posted February 17, 2009 Posted February 17, 2009 I havent got a ajustable panard rod and it looks fine. Quote
mel Posted February 17, 2009 Author Posted February 17, 2009 ok will give it a go with out one thanks for the replys back Quote
