Kennedy Posted February 19, 2009 Posted February 19, 2009 Hi everyone..got a bit of a problem..well more of an annoyance..I've read about n i know that the Glanza will usually idle about the 900rpm mark when warmed up but can i raise that a bit as it shakes the cabin/steering wheel etc.If you stick your foot on the accelerator slightly and raise the revs to about 950-1000 its fine and stops shaking?Is it possible or will i have to just live with it? Quote
ste91 Posted February 19, 2009 Posted February 19, 2009 You can raise it with the idle control obviously but the other thing is when was the last time you had it serviced? Worn ignition parts can cause lumpy idle. Quote
Kennedy Posted February 19, 2009 Author Posted February 19, 2009 I'm not sue when it was last serviced..i dont think it was to long ago.If i service the ignition parts and still have the problem how do do i raise it using the idle control valve? (if not a clue what/where it is lol :surrender:) Quote
Idrees Posted February 20, 2009 Posted February 20, 2009 You could have a worn engine mount mate.My old GT was like this but was fine after I fitted new engine mounts. :surrender: Quote
Kennedy Posted March 19, 2009 Author Posted March 19, 2009 Problem solved..turned the idle control valve up a little. well after i managed to find out where it was lolFor peoples future reference..its on the top left hand side of the inlet mani. Under a little circular piece of black rubber.Not sure if they are all then same (shud imagine they are) but its just a flat head screw.Can get a pic if people want? Quote
Raz Posted November 7, 2009 Posted November 7, 2009 Problem solved..turned the idle control valve up a little. well after i managed to find out where it was lolFor peoples future reference..its on the top left hand side of the inlet mani. Under a little circular piece of black rubber.Not sure if they are all then same (shud imagine they are) but its just a flat head screw.Can get a pic if people want?Hello mate, can i get a pic please, I'm not sure if i was fiddling with the correct stuff lol Quote
Kennedy Posted November 7, 2009 Author Posted November 7, 2009 Just realised that post is wrong it's the top right. I'll get pics later if I get chance Quote
Raz Posted November 16, 2009 Posted November 16, 2009 Just realised that post is wrong it's the top right. I'll get pics later if I get chance Please do so matethanks Quote
Kennedy Posted November 16, 2009 Author Posted November 16, 2009 I'll get a pic later on today 4 you. Quote
Kennedy Posted November 16, 2009 Author Posted November 16, 2009 Had a few things to sort mate this evening and its to cold n dark to go n get a pic.I will get one for you though.But if you look at the top right of the inlet mani the is a black circular piece of rubber about 1cm wide take that out n theres a flat head screw there..just warm up your engine the might slight adjustments to that.Cant remember which way is which though lol Quote
Russleh Posted November 16, 2009 Posted November 16, 2009 still not really problem solved though lol will still be shakey when its ideling where it should so would ya not be better changing ignition parts and mounts anyway and puttin the idle back where it should be. just my opinion though Russell Quote
Kennedy Posted November 16, 2009 Author Posted November 16, 2009 It's a temporary measure though Quote
Raz Posted November 22, 2009 Posted November 22, 2009 can you get a pic mate, i had a look at the manifold, can't see it, even if i doo see it still dont know about it :Sthanks!! Quote
Kennedy Posted November 22, 2009 Author Posted November 22, 2009 ^^I'll get one inabit for you mate, as i'm taking some snaps anyway Just a though, wht starlet do you have?If you have an N/A/GT it might be in a different place. EDIT: just looked througha a couple of your posts..you have a Glanza right? Quote
TRD Posted November 22, 2009 Posted November 22, 2009 It's at the same place for all ep82 and ep91. It's not recommended to play with the idle valve though! I would advice you to check the engine mounts instead and change those ignition leads and spark plugs Quote
Raz Posted November 22, 2009 Posted November 22, 2009 Yes i have Glanza! And nice, Thanks alot!! mate Quote
Kennedy Posted November 23, 2009 Author Posted November 23, 2009 Let us know how you get on, remember to warm your engine before you start adjusting. Quote
Asad Posted November 23, 2009 Posted November 23, 2009 yup, make sure everything is turned off lights, heater, gadgets etc etc Quote
