hello guys,
i have got a 1993 ep82 and the gearbox has gone i was just wondering if the gearbox of the glanza fits on if so does it just go straight on with no problems?
also where is the best place to get a gearbox?
^ requiers a bit more work..you need the one off the Corolla G6 with the 1.3 engine...if you get the G6R one off the 1.6 you have to swap the bell housings.
Just stick with a glanza or gt one, you want to be changing gear as little as possible in a turbo car...putting the 6spd in will mean your going to be changing more often...
Someone breaking a gt or glanza will be your best bet for sourcing one.
  • 2 weeks later...
hi jus a qwik question if someone gets a 6 speed box from g6 1.3 wot do u need to fit it in a starlet or is it a direct swap
