bucketep91 Posted April 4, 2009 Posted April 4, 2009 what is the sensor at the top left hand side of the intlet manifold? its making a loud ticking noise and doing my head in Quote
ToyotaTech15 Posted April 4, 2009 Posted April 4, 2009 Are you sure its not your injectors?One of them makes a loud ticking noise on the 4efteIts close enough to be mistaken for that sensorGary Quote
bucketep91 Posted April 4, 2009 Author Posted April 4, 2009 i dunno mate but it is quite loud doing my head in. its never been this loud Quote
Guest dominodon Posted April 4, 2009 Posted April 4, 2009 That would be your injectors very comon ticking noise nothing to worrie about Quote
bucketep91 Posted April 4, 2009 Author Posted April 4, 2009 the car is doing my head in atm its not boosting properly, im gettin oil out of the oil breather and i was using a bailies dump valve an it was pusing oil out, and my decat seems to have lost some bolts for some reason lol Quote
MadMan Posted April 4, 2009 Posted April 4, 2009 the car is doing my head in atm its not boosting properly, im gettin oil out of the oil breather and i was using a bailies dump valve an it was pusing oil out, and my decat seems to have lost some bolts for some reason lollost bolts out your decat jeezoo man sure someone aint slowly stealing it lol Quote
bucketep91 Posted April 5, 2009 Author Posted April 5, 2009 lost bolts out your decat jeezoo man sure someone aint slowly stealing it lollol its an autobhan decat, the 2 top bolts are still there, i checked the other day and the two bottom 1s are missing :-S lol Quote
CraGle Posted April 5, 2009 Posted April 5, 2009 same happened, to mine, no matter how tight i did the decat bolts up, theyd still come undone :/ Quote
WallaceGlanza Posted April 5, 2009 Posted April 5, 2009 That would be your injectors very comon ticking noise nothing to worrie about Nope, its actually the idle control valve he's talking about.If you unplug the electrical plug going into it you'll notice the revs drop slightly and the ticking will stop.If you have an excessive amount of oil coming out ofthe breather then unfortunately your piston rings may be badly worn best to do a compression test to check the health of the engine. Quote
MadMan Posted April 5, 2009 Posted April 5, 2009 Nope, its actually the idle control valve he's talking about.If you unplug the electrical plug going into it you'll notice the revs drop slightly and the ticking will stop.If you have an excessive amount of oil coming out ofthe breather then unfortunately your piston rings may be badly worn best to do a compression test to check the health of the engine.i am able to do these mate if you need one done as for not too far awaycheers Quote
bucketep91 Posted April 5, 2009 Author Posted April 5, 2009 Nope, its actually the idle control valve he's talking about.If you unplug the electrical plug going into it you'll notice the revs drop slightly and the ticking will stop.If you have an excessive amount of oil coming out ofthe breather then unfortunately your piston rings may be badly worn best to do a compression test to check the health of the engine.i was thinking it was piston rings, its been doing it a while now. thanks matei am able to do these mate if you need one done as for not too far awaycheershow hard is it to do? that would be great mate Quote
WallaceGlanza Posted April 5, 2009 Posted April 5, 2009 You can buy a compression tester from halfords for less than £20 then all you need to be able to do is remove your spark plugs as thats where the tester go's. Quote
WallaceGlanza Posted April 5, 2009 Posted April 5, 2009 First thing is to disconnect the king lead from the distributer and the efi fuse so there's no fuel and no spark. You are also supposed to do it with a warm engine.Then you remove the spark plug from the first cylinder, screw in the tester then with the throttle fully open crank over the engine on the starter until the gauge stops reading any higher (maybe 5secs of cranking) then take the reading remove the tester and refit the first spark plug then move onto the second cylinder.Repeat it for all 4 cylinders and compare the readings, they should be all be roughly the same and in the range of 150-180psi on a healthy engine. Quote
bucketep91 Posted April 5, 2009 Author Posted April 5, 2009 good man cheers bud.this should be fun and games lol Quote
