its premapped, it also removes speedcut and fual cut.
pricey bit of kit but great for running over a bar
goin rate for them is £400 ish
this starlet is running one on a standard turbo with a g reddy boost controller, its currently running a bar can i up this and how? also can i upgrade the turbo and retain the ecu, if so which turbos?? cheers lol
sorry i ment to say its good for unlocking the limit of fual cut to get to a bar, which incidently is about the maximum the ct9 can run before turning into a huge hairdryer.
you can upgrade the turbo and retain the ecu but id advised to get a fualing check after resetting the ecu to see how it fairs with the new turbo then use a fpr if needed.
if your running the standard mani id upgrade that first,
cheers, yeah i got a upgraded manifold without the restriction in number three, would a hybrid ct9 running with my current setup (wepr fmic, relocated air filter to front, manifold, fuel pump, toms ecu, profec type s boost controller) give a sizable enough increase of power, or in your opinion should i look to a different turbo altogether, also im situated in the london/kent/essex area is there any recommended specialists who can supply and assist in safe installation, thanks again
lmfao
On topic: as far as I know the TOMS ECU is similar to other plug & play ECUs like the Blitz one for example.
