CRAIG-SR Posted April 9, 2009 Posted April 9, 2009 Got some GROOVED BRAKE DISCS EBC YELLOW STUFF PADS today, Went to my mate to have them fitted but he said the disc fitted the hub but the caliper would not go over the disc with the pads on, the discs are 255MM X 22MM VENTED 4 STUD, been told they should of fitted tho, by some one else. Can anyone help me on this.i have got the yellow stuff pads on Quote
Dave@TM-Developments.com Posted April 9, 2009 Posted April 9, 2009 1.3i (EP81) - ABS (54mm centre) 90-91 * 229 16 41.3i (EP81) - ABS (55mm centre) 92-95 * 229 16 41.3i (EP81) + ABS 92-95 * 238 18 41.3i 16V (EP91) - ABS 96-5.96 * 229 16 41.3i 16V (EP91) + ABS 96-5.96 * 238 18 41.3i 16V (EP91) 6.96-> * 238 18 4Turbo (EP82) - 54mm centre -1992 * 254 18 4Turbo (EP82) - 55mm centre 1992-96 * 254 18 4Turbo (EP91) - 55mm centre 1996-> * 254 18 4Hope that helps Quote
rob_bower Posted April 9, 2009 Posted April 9, 2009 i thought the sr's had 238 x 18mm discs which is what dates list says too! Who said they would fit? Quote
Bourkey Posted April 10, 2009 Posted April 10, 2009 Quick question, Was the piston in the caliper pushed back in for the new pads??? If not then the caliper wont go on as the gap will be too small .Bourkey Quote
Starlet__SR Posted April 10, 2009 Posted April 10, 2009 Also, check your sliders, they can be prone to seizing up, so just check them over, bit of grease will help Quote
CRAIG-SR Posted April 10, 2009 Author Posted April 10, 2009 I was not there when he was doing them.Tho thinking now when i went back over he was just putting the last pad on and he was just doing the pistons then. So should they fit anyway?Thanks peolple for the help Quote
CRAIG-SR Posted April 12, 2009 Author Posted April 12, 2009 So if the discs wont fit because of the caliper, would glanza calipers fit or wont they because of the ABS? I want these discs on so am trying to find out wot to do or if they will fit. Thanks.?? Quote
