Mr SeZ Posted May 28, 2006 Posted May 28, 2006 i have a GAB rear strut brace which i'm gonna fit. i'm pretty sure you have 2 modify the plastic surrounding the struts 4 it 2 fit. does anyone have any pics of 1 fitted, so i can c how they go. doesn't matter if its not a GAB. cheers Si Quote
Blue Icarian Wings Posted May 28, 2006 Posted May 28, 2006 I presume you know the pyramid shaped covers come off (grasp car-width-ways squeze and they should come out), you can then see the bolt you'll be sticking it on thenI think I read somewhere the cusco one sat over the plastic so the best way to put it on was to remove the plastic panel slip it through the hole and put the whole lot back together Quote
Blue Icarian Wings Posted May 29, 2006 Posted May 29, 2006 Not got round to fitting a brace myself yet, but from the collection of pics I took when wiring in the parcel shelf I'll show some bitsRear passenger side panel off, but boot panel still in, the cover is off but you can see the bits where the cover clips in.This is of the left but shows the clip bits clearerLift it up and off a bit, note the seat has been removedPush it out of the way, note the seat belt is still attachedAnd theres the bolt exposed ready to recieve the strut (this pick for anyone who's wondered where the wiring stuff is or whats under there)Now I'd push the boot panels together, slip the brace through them, bolt it down and reassemble your car!To get there,.....First pull up the rear passenger seat bases (hold in the center back and pull), so the passenger panels can be moved, also might as whell unbolt the rear seat backs nowPull up the door floor guard (poppers) you need to do this to get the passenger panel outThe passenger panel pulls out (poppers) but has a lip that fits under the rubber thing that goes around the rear passenger window and also attaches to the panel on the pillar, you will need the seat bases up to do this, this panel is an arse to refitNow you may remove the boot panel, remove the rear setas if not done alreadyThere is a dark piece of plastic around where the seat belt comes out, pop it off (clip), it reveals two bolts, take them out, straight down in an indent remove the screw, off to left is another screw that was covered up by the passenger panel, remove that, the last two are crappy plastic screw things, one is straight down again from the first metal screw (under(lower) the lid thing for the jack), the second faces inwards towards the front of the car in the rear beam across the bottom of the boot doorIf you can still remember what you did all that for, do it! Thats my guide for dismantling the rear inside of your car, I took the center column and bits around the gear stick off a while ago if anybody wants to see that,........ Quote
Jozinobi Posted May 29, 2006 Posted May 29, 2006 Hey Wings.Awesome pics. You have done more stripping than I ever done lol (you can keep your hat on)Its a right bugger getting those panels off when I was putting in my c pillar bar.I had to remove the pillar skirts, I've left them off. But to get to them you need to unbolt a few things and undo a few other skirts as well around the seat belts and the passenger windows.You should also mention to people who want to strip the rear of the car that quite a bit of strength has to be used to unpop certain parts lol and to do it carefully, not easily done.I would like to see the pics u mentioned around the gear stick, just a few if poss.Peace OutJoz Quote
Mr SeZ Posted May 29, 2006 Author Posted May 29, 2006 cheers buddy much appreciated. you should try changing a dash. me and my mate did it the weekend. if you r thinking about doing it, don't. LOL! Quote
Blue Icarian Wings Posted May 29, 2006 Posted May 29, 2006 Thanks and will do Joz, though I must admit I used SiCaln's Start button thread as a guide.Moving in with the girlfriend is being expensive so I can't afford buy lots of bits like you are now, all I have is time and my electric screwdriver! No worries Mr SeZ glad to help EditJust looking through the pics, the first ones I have are after the bit of plastic over the handbrake has come off, and a lot of blurry close up! Will get some better pics and amke a proper guide at some point Quote
