No I don't have a GT/Glanza... well not yet anyway but I will most probably have a GT next year so I want to work a few things out.
What else would be needed to run 180-190 bhp at 1 bar and would this setup get somewhere near it:
Full service/oil change
Full Exhaust System (whatever's good value for money)
Exhaust Manifold (probably something like Zisco ram style)
Decat
Air Filter relocated to front
FMIC (probably a HDi one or similar)
HKS Actuator or similar
Standalone ECU, Blitz or similar
And of course a boost gauge and a BOV :thumbsup:
So what else needs to be done? Ported wastegate? EBC?
I'd remove the aircon as it's not much use in this country.
As for the ECU would a standalone one like the Blitz or TOM's work fine with the above mods at 1 bar and give the correct fuelling?
I would not recommend the self learning ECU's, I'd rather go for something like an Emanage and get it properly set up.
Some higher heat range spark plugs.
So Emanage Blue then I suppose...
What about getting it setup though, I haven't heard of any places local to me that do it.
I have a EMB and have found two places locally for mapping, so have a little look around? Or maybe travel to get it done, it'll be worth it!
Another thing is how would I get there before getting it mapped? Fit all the parts then just drive there but take it easy?
Just fit everything and drive it on low boost, and drive it slowly making sure it doesn't creep etc! One eye on the road and one on the boost gauge. :thumbsup:
I doubt you'll make 190 on an old CT9 with an old engine tbh mate. Over on the Aus Starlet Club they are chuffed to make 150whp on a CT9 setup, so be happy with 170/180 at the fly.
Spec list looks OK, but if I were you I'd buy an eManage or even a Unichip as opposed to spending £500 on a JAM ECU. You can pick up 2nd hand emanages (and espeically unichip's) for fairly cheap, even with mapping on top it would only just be more expensive than a JAM and will probably give you much better results!
Just my 2p.
Just my 2p.
Cheers, that's the sort of reply that I was looking for, so I suppose I'd have to go for a hybrid turbo for 190-200 then?
What about going for some different mods aswell as just the "bolt ons" like port & polish the head for example?
I know there are a few people on here with good power figures on CT9's @ 1 bar, but ideally I want a reliable 180 bhp rather than a struggled 190-200.
theres a few places in birmingham area mate weston performance in solihul are probally 1 of the best they set danes sps car up i think!
Oh that'll do then, that's just down the road.
GT_Matchew from sutton coldfield made 191 bhp on a ct9 at 1 bar with emanage so its achievable.
As for mapping you could try weston performance but im getting mine done by Nick @ Tuning Developments.
Last question for now as I don't want to go into it to much because it's atleast 12-14 months before I get a GT, but which of the mods I posted above would I be able to do straight away without the problem of boost creep and fuel cut?
I know the actuator needs to be set to 12psi (somewhere around 0.8 bar?) to avoid fuel cut.
If I was to port the wastegaste first before anything else would this mean I could stop worrying about boost creep, and just do whatever mods and run it at 12psi?
Yeah but he had a fairly low mileage engine/turbo! Not to mention he had a good setup all looked after by an eManage! Also if you're looking for 190/200, hybrid is definitely the way to go! If you did manage to peak 190 out of a normal CT9 I doubt it would last much longer! Also dub7 made 200+ on a CT9, but with a fully rebuilt engine and ported head, and again I'm sure that CT9 was strained to its limits!
Fuel cut is around 12-13-ish Psi yeah, so you'd need to set it below that. It would be a great idea to port the wastegate before doing anything, and run a nice steady 12ish Psi without massive amounts of creep. Very good idea in fact!
