ste91 Posted May 6, 2009 Posted May 6, 2009 I was pulling off from an island went to change gear, clutch pedal went all floppy (like it was stuck on), couldn't change gear.I think it's the cylinder thing as there's fluid pissed out everywhere...Sorry for the bad explination but hopefully someone has some idea of what I'm talking about - is this going to be expensive to fix? Quote
WallaceGlanza Posted May 6, 2009 Posted May 6, 2009 You can get new clutch slave cylinders from camskill and they are pretty easy to fit. Quote
ste91 Posted May 6, 2009 Author Posted May 6, 2009 How can I tell if it's the master/slave cylinder or whatever? Quote
200sx-Starlet-Jay Posted May 6, 2009 Posted May 6, 2009 yeah defo that mate, is fluid leaking out of both or just one?! Quote
ste91 Posted May 6, 2009 Author Posted May 6, 2009 Fluid like ontop of the gearbox, that's the slave cylinder yes? Quote
200sx-Starlet-Jay Posted May 6, 2009 Posted May 6, 2009 Fluid like ontop of the gearbox, that's the slave cylinder yes? the one thats on the gear box at the front, next to the engine?! Quote
WallaceGlanza Posted May 6, 2009 Posted May 6, 2009 Fluid like ontop of the gearbox, that's the slave cylinder yes?Yes, if its leaking from there then its pretty clear its gone. Quote
ste91 Posted May 6, 2009 Author Posted May 6, 2009 Just found another possibility...Where my air filter is it looks like it has rubbed on a pipe and made a hole in it. So I think it might be a simple job of replacing the pipe and getting the air filter so it's not rubbing on it. Quote
