Amjad Posted May 20, 2009 Posted May 20, 2009 Hey guys, I've noticed a little nagging problem, my interior light DOES work when you switch the lever to ON, but when it's on the DOOR setting, and the doors are open, it doesnt switch on..Any ideas as to what might be wrong? Is there like a switch by the doors that maybe wont release when I open the doors? Because I can't see one! Thanks,Amjad Quote
ToyotaTech15 Posted May 20, 2009 Posted May 20, 2009 There will more than likely be a button for each door, cant really remember,If you open the doors there will be a little black grommet like rubber thing that pushes in when the door pushed against it,If they are ok it will probably be the switch in the light itselfHope this helpsGary Quote
Bean Posted May 20, 2009 Posted May 20, 2009 take the rubber grommets off that cover mentioned above then take the door switches apart and clean all the contact up inside. they get all corroded and stop working, easy to do ive done it on both the starlets ive owned. Quote
Guest dominodon Posted May 20, 2009 Posted May 20, 2009 quite a few starlets have these problems as the lad said should work then Quote
Amjad Posted May 20, 2009 Author Posted May 20, 2009 Awesome fellas! I'll have a crack at it tomorrow, thanks! Quote
Mez Posted May 21, 2009 Posted May 21, 2009 haha this happened to Mo's car - dun mean to laugh i know its annoying - but it came back on, on its own one day if i remember correctly?? anywho's good luck fella Quote
