Steve GT Posted June 10, 2009 Posted June 10, 2009 hi just a quickie1st whats a AVCR what does it do and mean etcsame question for a SAFC. I've been told i need one but dont know what is means lolcan anyone help please thanks Quote
Guest Enzo Posted June 10, 2009 Posted June 10, 2009 close ste, safc stands for super air fual computerit controls the air fual ratio. you will need an uprated pump to run it properly,increase the fual pressure then trim it back with the safcim not sure what the avcr stands for but is that not a boost controller? Quote
Guest Enzo Posted June 10, 2009 Posted June 10, 2009 topic moved, please post in the correct section in future Quote
Jozinobi Posted June 10, 2009 Posted June 10, 2009 We'll be putting up a helpful EP Abbreviation Guide in the near future so no one is left clueless.Joz Quote
Guest Enzo Posted June 10, 2009 Posted June 10, 2009 there is one abreveation guide already but does not cover tuning equipementclicky Quote
RobSR Posted June 10, 2009 Posted June 10, 2009 SAFC = Super Air Flow Converter...basically, its a simple fuel controller that modifys the signal from the map sensor to make the car run richer or leaner..you can run one without an uprated pump/reg, and you can also remove fuel cut with it, if tuned corectly AVCR is a boost controller made by Apexi (who also make a SAFC) Quote
