Hi guys, wondering if anyone can help.
I've got a square light starlet gt and the clutch is too far down and the bite is right at the bottom, is there any way to adjust the clutch cable to make the bite higher up.
Many thanks. Danny
Are they definately cable?
if its hydraulic there will be adjustment on the pedal
If its cable there will possibly be adjustment at the gearbox end
Not 100% sure about older gt's thou
hope this helps
Gary
If you get in under the dash and look towards the top of the pedal arm, you should see a bolt that acts as a stopper for the pedal arm. Loosening/tightening this will adjust where the bite is.
Hope this helps ^_^
