aaron Posted June 24, 2009 Posted June 24, 2009 just bought a apexi neo 4 ma glanza.just wondered if they easy to fit maself...saves me paying guy to fit and then paying to tune up aswellcheers Quote
nicwan8 Posted June 25, 2009 Posted June 25, 2009 just bought a apexi neo 4 ma glanza.just wondered if they easy to fit maself...saves me paying guy to fit and then paying to tune up aswellcheersIf you have the wiring colour of your wiring loom guide, it's easy.Shave the wire, tap the Neo's wire, solder it, silicone heat wrap and you are done Quote
aaron Posted June 25, 2009 Author Posted June 25, 2009 sounds easy when ya say it like that,only i aint got the loom guidewhere would i wire it up 2...ecu wires? Quote
Bean Posted June 25, 2009 Posted June 25, 2009 the wiring for these should be pretty much the same for an safc shouldnt it? as im guessing it does the same job. Quote
nicwan8 Posted June 25, 2009 Posted June 25, 2009 the wiring for these should be pretty much the same for an safc shouldnt it? as im guessing it does the same job.Yep. wiring like SAFC2.Do a search in austarletclub.com for 4efte wiring diagram. Quote
RobSR Posted June 29, 2009 Posted June 29, 2009 Get on apexi's website, there is a support section that has all the wiring diagrams, it will basically be the same as the safc II, as in, power, ground, rpm, knock and airflow. Quote
