ollie1.3i Posted June 25, 2009 Posted June 25, 2009 Hijust needin people advice on wether its easy enought to change a cv joint on a starlet the out joints that is.and do i need to pull the whole shaft out of the gearbox or can i leave in as im only changing the out joint any advice is welcome thanks ollie Quote
dave200 Posted June 25, 2009 Posted June 25, 2009 hi mate theyre pretty easy to change to be honest aslong as you have the tools you can pull the shaft out without taking the inner joint out of the gearbox if you no what a mean its just 3 circle bearings that attach it to the hub sorry for the sh*t explanation lol good luck Quote
Steve GT Posted June 25, 2009 Posted June 25, 2009 its a lot easier to pull the driveshaft out of the gearbox. to be honest youll struggle to rebuilt the joint with it on the car as theres a ser clip (not sure how its spelled) in the outer joint that youll need to get out and that would be really tricky to do.so id say take the whole lot mate then you can do everything properly and just bang it straight back in Quote
ollie1.3i Posted June 25, 2009 Author Posted June 25, 2009 k thanks got 2 of em to do lol right and left =S stupid car Quote
motion Posted June 25, 2009 Posted June 25, 2009 WTF!?.........@ollie1.3: your avatar looks like my enginebay? Quote
ollie1.3i Posted June 25, 2009 Author Posted June 25, 2009 Im in the middle of transformin mine like yours but ive completly slammed mine now =P Quote
motion Posted June 25, 2009 Posted June 25, 2009 Im in the middle of transformin mine like yours but ive completly slammed mine now =Pgood luck! Quote
Starlet__SR Posted June 27, 2009 Posted June 27, 2009 Just get a copper hammer, quick sharp blows to the back of the joint, as for fitting, fit the hub nut, and still use the copper hammer. Gentley tap it on.Damien Quote
RobSR Posted June 29, 2009 Posted June 29, 2009 i would personally take the whole shaft out, easiest way to do this, take the hub nut off + split pin etc...get the car jacked up, take the 2 nuts and one bolt off the lower arm, and loosen the anti roll bar link. Cut the metal band off that holds the inner boot onto the inner driveshafts mounts/cv. As you have taken off the 3 lower arm nuts/bolts and loosend the ARB links you will have enough movent to "lift" the hub/ball joint out of the lower arm. Then simply pull the hub outwards and the shaft will pop out from the gearbox side. once its cleared the box, you should be able to pull the outer CV/shaft out the hub.Once the shafts out, obviously get the boot and cv off, change the cv, and remeber to put the cir-clip back in.Then just trace your steps backwards...as youve cut off the metal band, you can use cable ties to hold the cv boot on.Put it all back together, and off you go! Dont forget to tighten the ARB links up again though! Quote
Starlet__SR Posted June 30, 2009 Posted June 30, 2009 What you've just described Rob is a total waste of time, there's no need at all to remove the whole shaft, it's pointless and a waste of time, plus you'll lose gearbox oil, get someone to hold the shaft, a quick blow is all it takes, if you can't do that then let a garage do the work.Damien Quote
Rickstar Posted June 30, 2009 Posted June 30, 2009 Hey bud. my c.v has just gone.. just wondering how much the part cost you? i got a quote for £35. Is there any where cheaper? or is this a good price? Ricci Quote
Starlet__SR Posted June 30, 2009 Posted June 30, 2009 Thats a good price, just make sure you get the right c.v joint kit, the non abs and abs are two totally different seals.Damien Quote
Rickstar Posted July 1, 2009 Posted July 1, 2009 Thats a good price, just make sure you get the right c.v joint kit, the non abs and abs are two totally different seals.DamienCheers bud. Will do. Its pissing me off!!! Quote
RobSR Posted July 1, 2009 Posted July 1, 2009 What you've just described Rob is a total waste of time, there's no need at all to remove the whole shaft, it's pointless and a waste of time, plus you'll lose gearbox oil, get someone to hold the shaft, a quick blow is all it takes, if you can't do that then let a garage do the work.Damienhow else are going to get a cv off wothoout taking the shaft out, when its "sandwiched" between the hub and shaft...and also how are you going to loose g.box oil? cv grease yes, g.box oil no.. Quote
Starlet__SR Posted July 1, 2009 Posted July 1, 2009 Unbolt the top two bolts for the hub carrier, undo the 2 bolts and nut on the bottom arm, move out of the way, your choice whether or not to unbolt the caliper, disc etc, but does help, leaving you with the c.v. joint and the driveshaft at your disposal, saves removing the shaft etc:)Damien Quote
