ok i'v got the old actuator off and there is two pipes going into it. on my new actuator there is only one place for a pipe to connect.Is this right and if so which one do i connect and what do i do with the other oneicon9.gif
Thanks Jimbob
You connect the one that goes to the turbo housing, the short one
and you just block the other one that goes to the HI/LO boost solenoid with a screw or something :p
Just means you have no LO boost option
theres a way to get around this isn't there though? like connecting the other pipe somehow I've forgotten how you do it though lol
Yes, with the hks kits they come with a t piece which you can then keep the stock setup with.
