adee-ep Posted July 22, 2009 Posted July 22, 2009 how much power can the standard injetors work at? cheers aidan Quote
Steve GT Posted July 22, 2009 Posted July 22, 2009 i think its about 250bhp maybe a bit more.pretty sure they can easily hack 200bhp but im sure its a lot more Quote
adee-ep Posted July 22, 2009 Author Posted July 22, 2009 also i have a sytec 255 fuel pump in my house but i bought it for my civic could i use this on the glanza? Quote
WallaceGlanza Posted July 22, 2009 Posted July 22, 2009 I wouldn't want to run the stock injectors at any more than 220bhp really, over that and the duty cycle will be quite high and you want it below 80%.Its a 255lph fuel pump that is normally fitted when upgrading so I'm sure you'll be able to fit it, with the walbro I fitted you needed to cut and splice the wires anyway. Quote
adee-ep Posted July 22, 2009 Author Posted July 22, 2009 it says its a sytec walbro 255 feul pump so that should be good then? what injectors should i go for if iam going for in the range of 270hp? is there any you can use from a celica or anything? cheers aidan Quote
Ryan-11 Posted July 22, 2009 Posted July 22, 2009 you would prob be best with a set of 440cc or 460cc injectors Quote
adee-ep Posted July 22, 2009 Author Posted July 22, 2009 cheers ryan. any injectors off a gt4 i could use rather than splashing out on rc's ? cheers aidan Quote
Ryan-11 Posted July 22, 2009 Posted July 22, 2009 im sure some mazda injectors work but i wouldnt quote me an that Quote
Glanza_cl Posted July 22, 2009 Posted July 22, 2009 you can get a set of injectors from the RX7, they will suit you best probably.although if you google speed vision he does loads of different injector sizes specifically for the ep91/ ep82 Quote
adee-ep Posted July 22, 2009 Author Posted July 22, 2009 what year of a rx7 will the injectors work as il need the same obd surely. cheers aidan Quote
