Yes they will fit the FE block but I would advice to consider upgrading with 5FE cams instead, if I'm Reading your mind then that's what you must do instead. Lol:) I know you're looking for a bigger Turbo and bigger BHP figures :thumbsup: so come on matey, get a bigger block lol.
all the e series cams are the same, except for the 5e-fhe in the cynos (with the ACIS Manifold), which have slightly higher lift.
afaik the only difference in the fte cam setup is the springs. they are stiffer than the NA to cope with the higher rev limit.
