conal'sr Posted September 6, 2009 Posted September 6, 2009 im getting a set for free and wanted to know has anyone ever put them in a starlet(ep91)?or if anyone knows if its a straight fit or is some moding needed? Quote
Kennedy Posted September 6, 2009 Posted September 6, 2009 Think i've seen it done..although it could have been a paseo.You probably need to do a little bit of modding to get them to fit. Quote
conal'sr Posted September 6, 2009 Author Posted September 6, 2009 Think i've seen it done..although it could have been a paseo.You probably need to do a little bit of modding to get them to fit.thanks for such a fast responceyeah thats what i was thinking Quote
LukeSR Posted September 6, 2009 Posted September 6, 2009 What Kennedy said, doubt they would fit straight in! Quote
ToyotaTech15 Posted September 6, 2009 Posted September 6, 2009 pretty sure they wont fit inwith a little work anything will fit thou lolGary Quote
Hou Posted September 7, 2009 Posted September 7, 2009 I fitted a set to a Starlet SR, boy was that hard work, but do-able!The mounting points at the front need the locating pins removing, the lip on the front bending and they need bending inwards a few inchThe rear mount nearest the centre of the car on the seats aims at the floor, but the mounting point is at a right angle to that ie bolts into the central tunnel (not sure what to call it, you will see if you look at your seats). For this I used some lovely thick angle Iron Quote
Mikey Jay Posted September 7, 2009 Posted September 7, 2009 Think i've seen it done..although it could have been a paseo.You probably need to do a little bit of modding to get them to fit.You thinking of seeing them in my Paseo?The seats were modified to fit a Paseo before I had them, they were welded on to standard rails I believe.(Riko had the work carried out) Quote
Kennedy Posted September 7, 2009 Posted September 7, 2009 ^^yes thought i had seen it before They look quite comfy aswell Quote
Hou Posted September 7, 2009 Posted September 7, 2009 They are super comfy and they have adjustable bulster supports, so when coming into a tigt corner you can just tighten it to your ribs Quote
ToyotaTech15 Posted September 7, 2009 Posted September 7, 2009 They actually look smart,Never seen them beforeGary Quote
