Corolla Gti Seats?
I fitted a set to a Starlet SR, boy was that hard work, but do-able!
The mounting points at the front need the locating pins removing, the lip on the front bending and they need bending inwards a few inch
The rear mount nearest the centre of the car on the seats aims at the floor, but the mounting point is at a right angle to that ie bolts into the central tunnel (not sure what to call it, you will see if you look at your seats). For this I used some lovely thick angle Iron
Think i've seen it done..although it could have been a paseo.
You probably need to do a little bit of modding to get them to fit.
You thinking of seeing them in my Paseo?
The seats were modified to fit a Paseo before I had them, they were welded on to standard rails I believe.
(Riko had the work carried out)
