few hundred quid if you get second hand bits.
box, mounts, linkages, shifter box, clutch pedal, master cylinder and misc bolts etc.
youll also need a manual reverse light plug, as the auto one doesnt fit on the manual gearbox.
The car will run fine on the auto ECU, as the Manual one from EP82s won't fit automatic EP82s anyway.
I got all the bits to convert my auto from a crashed GT for £250, which was a lucky find, you will also need a manual flywheel on top of everything Rick said, manual dash clocks would help as well, though they aren't necessary.
Hope this helps,
Watsi
