when i got the car...the lad had already fitted the glanza rear axle to accomodate for the discs...problem is though hees drained the system in doing it (numpty!!). i presume there is still some fluid in the system...due to the front brakes havnt been tampered with, and im hoping that the master cylinder is still fine...but how should i go about in re-filling the system?? I've done brake bleeding plenty of times before but I've never came across a dry system :S
right this is my field first of all undo the rear bleed nipples and fill the master to the brim
this is called gravety bleed you may need to tap the flexy hoses to help the fluid through
this should stop getting an air lock in the system
once your at this stage its just a case of bleeding as normal starting with
the ferthest away from the master cylinder and doing one corner at a time
this job would be alot easier with a preasure bleeder though.
there is nothing to prime
hope this helps
john
