adz_sportif_turbo Posted September 23, 2009 Posted September 23, 2009 the actuator on the ct9 is real soft...is that because it has an input and an output?? because the actuator isnt sealed like conventional ones its got to be set so it doesnt take very much pressure to open the wastegate?? Quote
ste91 Posted September 23, 2009 Posted September 23, 2009 Standard actuator yeah? They're crap, get a HKS one. Quote
adz_sportif_turbo Posted September 23, 2009 Author Posted September 23, 2009 yhh im gonna defo change it...hks sounds like the choice!! i was just curious about the input and output on it...how does it even open the wastegate when it has an output!?! i presume through the softness of it?!? Quote
Glanza_cl Posted September 23, 2009 Posted September 23, 2009 your putting up alot of post about little things that have been covered a million times... go into the tech section or click the search button and have a nosey through.there was a massive thread on tgtt about the catch can... actuator has been done sooo much just type in actuator into the search bar actuator:http://www.ukstarletclub.com/forums/index....ghlite=actuatorcatch can:http://www.toyotagtturbo.com/forums/showthread.php?t=29532 Quote
adz_sportif_turbo Posted September 23, 2009 Author Posted September 23, 2009 yes but not the answers i need...like this is a good example or a conventional pcv system:id imagine the hose closest to the filter in the diagram on a starlet is were the recirc bov is...but when people have been plumbing in a oil catch tank to vent 2 atmosphere they have been plumbing this line into the tank!! the way in which you put the fumes back into the inlet mani you put a filter on this part of the rocker cover. but i want to vent 2 atmosphere though...and do it proplerly.you c my what i mean??does it matter if you dont get clean air into the system?? can you just use this port on the rocker as another way to vent out fumes??is it possible to properly plumb in a catch tank to vent 2 atmosphere?? i dont mean 2 sound like im havin a whinge and soz its in the wrong section i just thought it was relevent to the conversation Quote
Glanza_cl Posted September 23, 2009 Posted September 23, 2009 you shouldn't really vent to atmosphere as it can get frowned upon...it's not classed as illegal but there is no problem with it going back into the inlet mani otherwise why would toyota design something to work that way.best way i know to run to catch can is: 1pipe of the pcv valve to catch can2pipe from inlet mani to catch can3rd run a filter of the rocker cover breather... as you stated you want to vent to atmospher so this way or having a filter on the catch can venting most variation of connecting will have the same effect. Quote
adz_sportif_turbo Posted September 23, 2009 Author Posted September 23, 2009 yhh i suppose!! i think i am going 2 do it this way!!thanks for the input mate Quote
adz_sportif_turbo Posted September 23, 2009 Author Posted September 23, 2009 one more question on wastegates...do you know if they open more and more and rpm increases to sustain the same boost pressure...or do they just open a certain amount and stay there?? Quote
Glanza_cl Posted September 23, 2009 Posted September 23, 2009 the actuator will bleed off pressure from around 3psi (i think, i'm not sure what is it on a 4efte) and will fully open once the correct pressure is reached e.g. 11psi, 0.8bar.the most efficient is to get a ebc as this can regulate the wastgate and can open/close to sout helping to reduce creep and aid in better and more accurate boost pressure Quote
scot-ish Posted September 23, 2009 Posted September 23, 2009 remember you need another pcv valve in the line to the inlet, otherwise the can will become pressurised Quote
adz_sportif_turbo Posted September 23, 2009 Author Posted September 23, 2009 cool scot-ish i will if i uprate the actuator to a hks unit will it improve spooling Quote
Glanza_cl Posted September 23, 2009 Posted September 23, 2009 if i uprate the actuator to a hks unit will it improve spoolingnot spooling, but the boost will be alot more stable and shouldnt creep as much, plus it's adjustable Quote
YoungStig Posted September 23, 2009 Posted September 23, 2009 just orderd mine from sumo power.fone him £94.88 delivered sweet Quote
