Marck glanza V Posted September 25, 2009 Posted September 25, 2009 hi does anyone have any pics of a zisco external wastegate manifold fitted to the car or has anyone had any problems fitting it Quote
Guest Enzo Posted October 4, 2009 Posted October 4, 2009 i had problems with mine man, it wont fit with the decat on. so had to hammer a dent into the zisco decat for it to fit.its not ideal and its putting pressure on the welds il try and fire some pics up when i have a chance. Quote
Guest Enzo Posted October 4, 2009 Posted October 4, 2009 is that an externaly gated tdo4 manifold or do you have an adapter plate? Quote
ste91 Posted October 5, 2009 Posted October 5, 2009 Has anyone had any problems with these manifolds cracking?I have tried searching on both here and TGTT but it seems either they are very good quality OR nobody wants to speak up about it but I have read one or two bad things so I'm not so sure. Quote
Sparky Posted October 5, 2009 Posted October 5, 2009 I've never heard a bad thing to be honest, their workmanship looks awsome! Quote
Guest Enzo Posted October 5, 2009 Posted October 5, 2009 mark has the same problems as me, must have been in that batch but the decat wont fit with the external waistgate pipe.gona pop up tonight to see his Quote
riko666 Posted October 5, 2009 Posted October 5, 2009 I've got a pinhole....hole, on my manifold, in a gap between the collector welding - but no cracks, even with heatwrap for a while, running it unbraced for a long while. They are well made, and the runner materials are thick - only issue I had is that the turbo outlet for the fmic fouled on one of the runners so I had to saw off a bit of the flange, otherwise, fine. Quote
Mart Posted October 5, 2009 Posted October 5, 2009 This happened to mine aswell Riko. I had to saw one of the flanges aswell... Quote
Bean Posted October 5, 2009 Posted October 5, 2009 ive got an externally gated td04 zisco setup and im pretty sure it was one of the first if not the first td04 ones they made. I had no fitting problems with mine at all. the only problem is that the turbo inlet pipe sits a bit close to the oil filter but i have a greddy oil relocation kit so im ok, i think they have changed this after mine though. Oh and one of the bolt holes for the brace doesnt quite line up but thats not a big problem. im very happy with mine. the black paint they come with you might aswel rub it down first as it will last about 10 mins lol. Quote
