could someone make a list of where all the earths are on starlet. just wanna check mine are all on which i doubt. pictures would be helpful but not needed.
cheers
Russell
Yup.......on my N/A
driverside mounting
battery > front slam panel + gear box
underneath the airbox theres one attached to a metal plate on the chassis > gearbox
drivers side headlight area
on the back of the inlet mani
these are what i can remeber off the top off my head...i renewed all of them, sanded the paint + rust away not so long ago.
they will be banks of earth like on any car one or two will be in the boot behind plastics near one or both lights, check both foot wells below the A pillars defo near the fusebox and one near the fusebox in the engine bay plus all engine earths gearbox, near starter one to the head and alternator.
from the battery to the slam panel to behind the battery to somwere near the n/s strut mount to strut mount. mabey one going to the gearbox. i think ive got a pic ill try and find it.
thanks folks ill make use of this tomorrow and make sure my car is all earthed properly because im sure i ended up with a stray wire that lookin like it was an earth <_<.
thanks folks ill make use of this tomorrow and make sure my car is all earthed properly because im sure i ended up with a stray wire that lookin like it was an earth :blink: .
make sure its not the ariel for the alarm if you short it to earth it can kill it <_<
