nazquflilma Posted October 20, 2009 Posted October 20, 2009 How do you remove the back door trim? Parts seen in link. clickTried to unscrew the fasteners however although fasteners turn screws do not seem to come off....Any help? Quote
nazquflilma Posted October 20, 2009 Author Posted October 20, 2009 I need to sort this out asap....the previous owner of my car decided to use self-tapping screws to affix a number plate holder. ;) These screws are quite rusty, and the spray is damaged (not to mention the holes in the metal). Any help??? Quote
Nanglebadger Posted October 20, 2009 Posted October 20, 2009 simple, pull.sounds harsh, but thats how they come off. pull.Phil. Quote
nazquflilma Posted October 21, 2009 Author Posted October 21, 2009 simple, pull.sounds harsh, but thats how they come off. pull.Phil.So they're actually just clips? Quote
nazquflilma Posted October 23, 2009 Author Posted October 23, 2009 So they're actually just clips?Tried pulling the thing off, but I can't manage :harhar: Quote
nazquflilma Posted October 23, 2009 Author Posted October 23, 2009 lol pull harder :harhar:But won't the whole trim snap if pulled too hard? Quote
micky boy Posted October 23, 2009 Posted October 23, 2009 cant you get a screwdriver behind and snap the clips then get some new ones its better than snaping the trim :harhar: Quote
nazquflilma Posted October 23, 2009 Author Posted October 23, 2009 cant you get a screwdriver behind and snap the clips then get some new ones its better than snaping the trim :harhar:Yeah I could but I hoped to do everything without doing any further damage..... Quote
micky boy Posted October 23, 2009 Posted October 23, 2009 lol just brack them i think they cost about £3 for 10 :harhar: Quote
Nanglebadger Posted October 23, 2009 Posted October 23, 2009 they are little popper thingys, they are a stubborn bastard to get off.Phil. Quote
Wantaglanz Posted October 23, 2009 Posted October 23, 2009 Get a small hook and pull out the bit with the screy heads on, donw pull it off it will break them! a small hook or a very small flat screw driver! Quote
nazquflilma Posted October 23, 2009 Author Posted October 23, 2009 Get a small hook and pull out the bit with the screy heads on, donw pull it off it will break them! a small hook or a very small flat screw driver!I Will try that tomorrow....thanks Quote
nazquflilma Posted October 24, 2009 Author Posted October 24, 2009 Done It's not difficult to do after you get a hang of removing the clips....will post a how to in the tutorial sections Quote
