Im trying to wire up my front foglights, I bought a wiring kit with a relay and an on/off switch. i plan to mount the switch beside where the headlight adjuster is, but i cant find anywhere to feed the wire from inside the car to the engine bay. Can anyone shed any light on this, is there a space that I can feed the wire through?
cheers
adam
on the left side by the fuel fliter on my car is a rubber on the Fire wall about mid ways down you can put a wire though there i have done that with all my wires any way it will come out behind the glove box
^^^^what they said, u'll see rubber plugs or bungs or however u interpret their shape on the firewall with big black wiring goin through them, thats the ticket there!
u can slice it open a bit further with a stanley if its real tight, or poke a screwdriver through with some string on the end thats tied to your wiring, then just pull the string and wiring through, bob's your uncle and fanny's your aunt!
Phil.
