Fitted my front cusco strut bar today to my ep91 uk spec starlet,and have a bit of a problem,my struts only have three mounting points and the cusco bar has four mounting holes,has anyone came across this problem before when fitting a cusco strut bar on a ep91 starlet with standard mountings?
cheers stevie
You must be using the standard top mounts then?
Im sure it will be fine with 3 studs, but most aftermarket top mounts like cusco have 4 studs.
Jack
